주요 콘텐츠로 건너뛰기
Compaq Evo N1000v Rear Fan Replacement
필요한 것
  1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: 1 단계, 이미지 1/1
    • Carefully remove the screws located inside the red circles.
  2. Compaq Evo N1000v Rear Fan Replacement: 2 단계, 이미지 1/2 Compaq Evo N1000v Rear Fan Replacement: 2 단계, 이미지 2/2
    • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
    • Push down on the spudger to lift the LED display upward.
    • Do this on both the left and right sides of the device as shown in the images.
  3. Compaq Evo N1000v Rear Fan Replacement: 3 단계, 이미지 1/1
    • Completely remove the LED display panel from the device.
  4. Compaq Evo N1000v Rear Fan Replacement: 4 단계, 이미지 1/1
    • Lift the keyboard up from the back end as shown in the image.
  5. Compaq Evo N1000v Rear Fan Replacement: 5 단계, 이미지 1/1
    • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  6. Compaq Evo N1000v Rear Fan Replacement: 6 단계, 이미지 1/1
    • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
    • Repeat this action on the right side of the lock.
  7. Compaq Evo N1000v Rear Fan Replacement: 7 단계, 이미지 1/1
    • Pull the keyboard upward to remove it from the device.
  8. Compaq Evo N1000v Rear Fan Replacement: 8 단계, 이미지 1/1
    • Unscrew the 3 screws as shown in the photo.
  9. Compaq Evo N1000v Rear Fan Replacement: 9 단계, 이미지 1/1
    • Remove the cable with the grip tweezers as shown in the photo.
  10. Compaq Evo N1000v Rear Fan Replacement: 10 단계, 이미지 1/1
    • Remove the rear fan.
    • Repeat these steps in reverse order to install the new rear fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
ryan
회원 가입일: 03/12/14
470 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 회원
UMASSD-VIJAYBHASKAR-S14S2G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 398
