주요 콘텐츠로 건너뛰기
Compaq Presario CQ60 Display Assembly Replacement
필요한 것
  1. Compaq Presario CQ60 Display Assembly Replacement, Slide battery latch: 1 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Slide battery latch: 1 단계, 이미지 2개 중 2개
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Display Assembly Replacement: 2 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement: 2 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Lift and remove battery
  3. Compaq Presario CQ60 Display Assembly Replacement, Unscrew keyboard: 3 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Unscrew keyboard: 3 단계, 이미지 2개 중 2개
    • Remove 3x M2.5x4mm
  4. Compaq Presario CQ60 Display Assembly Replacement, Lift keyboard: 4 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Lift keyboard: 4 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement, Lift keyboard: 4 단계, 이미지 3개 중 3개
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  5. Compaq Presario CQ60 Display Assembly Replacement, Detach ribbon cable: 5 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Detach ribbon cable: 5 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement, Detach ribbon cable: 5 단계, 이미지 3개 중 3개
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  6. Compaq Presario CQ60 Display Assembly Replacement, Remove screws: 6 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Remove screws: 6 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement, Remove screws: 6 단계, 이미지 3개 중 3개
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  7. Compaq Presario CQ60 Display Assembly Replacement, Disconnect ribbon cable: 7 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Disconnect ribbon cable: 7 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement, Disconnect ribbon cable: 7 단계, 이미지 3개 중 3개
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  8. Compaq Presario CQ60 Display Assembly Replacement: 8 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Display Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  9. Compaq Presario CQ60 Display Assembly Replacement, Remove bezel: 9 단계, 이미지 1개 중 1개
    • Fully remove bezel
  10. Compaq Presario CQ60 Display Assembly Replacement, Disconnect left hand cables: 10 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Disconnect left hand cables: 10 단계, 이미지 2개 중 2개
    • Disconnect the display cable
    • Disconnect the microphone connector
    • Pull out the microphone LED from it's clip
    • Unroute the cables from their holders
  11. Compaq Presario CQ60 Display Assembly Replacement, Wifi Antennas: 11 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Wifi Antennas: 11 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement, Wifi Antennas: 11 단계, 이미지 3개 중 3개
    • Pull the wifi antennas through from the back of the laptop
    • Unroute the antenna cables from their guides
  12. Compaq Presario CQ60 Display Assembly Replacement, Remove display assembly: 12 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Display Assembly Replacement, Remove display assembly: 12 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Display Assembly Replacement, Remove display assembly: 12 단계, 이미지 3개 중 3개
    • Remove 4x Phillips #1 M2.5x8mm screws from display hinges
    • Carefully lift display out making sure no cables are snagged
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mike B
회원 가입일: 11/07/13
1,045 평판
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 15
전체 시간: 743
