주요 콘텐츠로 건너뛰기
Compaq Presario CQ60 Keyboard Bezel Replacement
필요한 것
  1. Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: 1 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement, Slide battery latch: 1 단계, 이미지 2개 중 2개
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Keyboard Bezel Replacement: 2 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement: 2 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Keyboard Bezel Replacement: 2 단계, 이미지 3개 중 3개
    • Lift and remove battery
  3. Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: 3 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement, Unscrew keyboard: 3 단계, 이미지 2개 중 2개
    • Remove 3x M2.5x4mm
  4. Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: 4 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: 4 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Keyboard Bezel Replacement, Lift keyboard: 4 단계, 이미지 3개 중 3개
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  5. Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: 5 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: 5 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Keyboard Bezel Replacement, Detach ribbon cable: 5 단계, 이미지 3개 중 3개
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  6. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: 6 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: 6 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Keyboard Bezel Replacement, Remove screws: 6 단계, 이미지 3개 중 3개
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  7. Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: 7 단계, 이미지 3개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: 7 단계, 이미지 3개 중 2개 Compaq Presario CQ60 Keyboard Bezel Replacement, Disconnect ribbon cable: 7 단계, 이미지 3개 중 3개
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  8. Compaq Presario CQ60 Keyboard Bezel Replacement: 8 단계, 이미지 2개 중 1개 Compaq Presario CQ60 Keyboard Bezel Replacement: 8 단계, 이미지 2개 중 2개
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  9. Compaq Presario CQ60 Keyboard Bezel Replacement, Remove bezel: 9 단계, 이미지 1개 중 1개
    • Fully remove bezel
결론
작성자
1다른 기여자 명과 함께
Mike B
회원 가입일: 11/07/13
1,045 평판
안내서 9개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 274
