주요 콘텐츠로 건너뛰기
Compaq Presario CQ60-211DX Display Assembly Replacement
필요한 것
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Compaq Presario CQ60-211DX Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: 3 단계, 이미지 2개 중 1개 Compaq Presario CQ60-211DX Display Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garrett Carter
회원 가입일: 09/21/18
510 평판
안내서 4개를 작성함
2가이드 댓글
My laptop model Compaq predario cq61 h
Rashid 007 - 답글
Computer on but display light of computer is running
Rashid 007 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 1,495
