이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Start by making sure the CQ60 is powered down and that the disk drive is empty.
Flip the device over and remove the battery.
Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
Pull the frame forward, and then unscrew the three screws on each side.
Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
댓글 2개
My laptop model Compaq predario cq61 h
Rashid 007 - 답글
Computer on but display light of computer is running
Rashid 007 - 답글
