주요 콘텐츠로 건너뛰기
Compaq Presario CQ60-211DX Solid State Drive Replacement
필요한 것
  1. Compaq Presario CQ60-211DX Solid State Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop off and disconnect all sources of power.
    • Set the laptop on a flat surface with the bottom side facing up.
  2. Compaq Presario CQ60-211DX Solid State Drive Replacement: 2 단계, 이미지 1/3 Compaq Presario CQ60-211DX Solid State Drive Replacement: 2 단계, 이미지 2/3 Compaq Presario CQ60-211DX Solid State Drive Replacement: 2 단계, 이미지 3/3
    • Slide the battery release tab.
    • This will eject the battery.
    • Carefully remove the battery and set it aside.
  3. Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): 3 단계, 이미지 1/2 Compaq Presario CQ60-211DX Solid State Drive Replacement, Solid State Drive (SSD): 3 단계, 이미지 2/2
    • Use a PH1 screwdriver to unscrew the 2 screws that secure the hard drive cover.
    • Remove the cover.
  4. Compaq Presario CQ60-211DX Solid State Drive Replacement: 4 단계, 이미지 1/2 Compaq Presario CQ60-211DX Solid State Drive Replacement: 4 단계, 이미지 2/2
    • Unscrew the next three screws holding the hard drive in place.
    • Pull the black ribbon and slide the hard drive out of place.
결론
Garrett Carter
회원 가입일: 09/21/18
471 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 993
