주요 콘텐츠로 건너뛰기
Compaq Presario CQ62 Hard Drive Replacement
필요한 것
  1. Compaq Presario CQ62  Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Compaq Presario CQ62  Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • It is advised to work on this device only when it is OFF, to avoid electrocution risks. Please make sure your laptop is powered off.
    • On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
    • We do not have a battery on our device to show how to take it off.
  2. Compaq Presario CQ62  Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/2 Compaq Presario CQ62  Hard Drive Replacement, Hard Drive: 2 단계, 이미지 2/2
    • Loosen the two M2.5x3 mm Phillips screws securing the hard drive cover.
  3. Compaq Presario CQ62  Hard Drive Replacement: 3 단계, 이미지 1/1
    • On the same side as the two screws, there should now be an opening to lift off the cover. Using a plastic opening tool, sightly lift the case up to remove it.
  4. Compaq Presario CQ62  Hard Drive Replacement: 4 단계, 이미지 1/2 Compaq Presario CQ62  Hard Drive Replacement: 4 단계, 이미지 2/2
    • Remove the three M2.5x5 mm Phillips screws securing the hard drive assembly.
  5. Compaq Presario CQ62  Hard Drive Replacement: 5 단계, 이미지 1/1
    • Our laptop did not have a hard drive, so it is not included in the photo.
    • To remove the hard drive, detach it from the the hard drive connector. You can do this by pulling it gently with your hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roth Marcelin
회원 가입일: 10/06/16
726 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-6, Sullivan Fall 2016 USF Tampa, Team 2-6, Sullivan Fall 2016 회원
USFT-SULLIVAN-F16S2G6
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 33
전체 시간: 2,997
