주요 콘텐츠로 건너뛰기
Compaq Presario CQ62-215dx CPU Replacement
필요한 것
  1. Compaq Presario CQ62-215dx CPU Replacement, CPU: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down.
    • Remove all the 3.0mm Phillips #00 screws from the back cover.
  2. Compaq Presario CQ62-215dx CPU Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery, RAM, and hard drive.
  3. Compaq Presario CQ62-215dx CPU Replacement: 3 단계, 이미지 1개 중 1개
    • Remove four 1.2mm Phillips #00 screws under the battery.
  4. Compaq Presario CQ62-215dx CPU Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the laptop over, and open the laptop cover.
    • Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx CPU Replacement: 5 단계, 이미지 1개 중 1개
    • Use a spudger or your hand to lift the outside frame from the corner of the laptop.
  6. Compaq Presario CQ62-215dx CPU Replacement: 6 단계, 이미지 1개 중 1개
    • Remove all the 1.2mm Phillips #00 screws from the motherboard and in the top corner that secures the fan.
  7. Compaq Presario CQ62-215dx CPU Replacement: 7 단계, 이미지 1개 중 1개
    • Unplug the wires connected to the motherboard with a spudger.
  8. Compaq Presario CQ62-215dx CPU Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two 3mm Phillips #00 screws beside the fan.
  9. Compaq Presario CQ62-215dx CPU Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx CPU Replacement: 10 단계, 이미지 1개 중 1개
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx CPU Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx CPU Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the fan from the motherboard.
    • When reassembling, you will need to solder the fan back on to the CPU.
  13. Compaq Presario CQ62-215dx CPU Replacement: 13 단계, 이미지 1개 중 1개
    • Use the metal spudger to twist the lock tab on the component.
  14. Compaq Presario CQ62-215dx CPU Replacement: 14 단계, 이미지 1개 중 1개
    • Remove current CPU and replace with new component.
결론
작성자
3다른 기여자 명과 함께
Breana Thibodeaux
회원 가입일: 03/24/19
760 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S4G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 16
전체 시간: 1,401
