주요 콘텐츠로 건너뛰기
Compaq Presario CQ62-215dx Fan Replacement
필요한 것
  1. Compaq Presario CQ62-215dx Fan Replacement, Fan: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside down, and unscrew all the 3.0mm screws on the back cover with a Phillips screwdriver.
  2. Compaq Presario CQ62-215dx Fan Replacement: 2 단계, 이미지 1개 중 1개
    • Take out the Battery and the placeholder for the RAM and the Hard Drive
  3. Compaq Presario CQ62-215dx Fan Replacement: 3 단계, 이미지 1개 중 1개
    • There are four 1.2mm screws under the battery that are needed to be removed with a Phillips screwdriver.
  4. Compaq Presario CQ62-215dx Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the laptop back, and open the laptop cover. Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Once the keyboard is out, use the Metal Spudger or your hand in the corner of the laptop to lift the outside frame.
  6. Compaq Presario CQ62-215dx Fan Replacement: 6 단계, 이미지 1개 중 1개
    • You will have a bigger view of the entire motherboard and there should be screws that are still connected on it.
    • Unscrew all the 1.2mm screws on the motherboard and in the top corner that secures the fan with a Phillips screwdriver.
  7. Compaq Presario CQ62-215dx Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Unplug the wires connected to the mother board with the Metal Spudger
  8. Compaq Presario CQ62-215dx Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Unscrew the two 3mm screws beside the fan with a Phillips screwdriver.
  9. Compaq Presario CQ62-215dx Fan Replacement: 9 단계, 이미지 1개 중 1개
    • If all the screws have been removed, you should be able to lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx Fan Replacement: 10 단계, 이미지 1개 중 1개
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx Fan Replacement: 11 단계, 이미지 1개 중 1개
    • Use the Phillips screwdriver to unscrew the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx Fan Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the current fan from the motherboard and replace with new component.
    • When reassembling, you will need to reapply thermal paste on the CPU.
결론
작성자
2다른 기여자 명과 함께
Breana Thibodeaux
회원 가입일: 03/24/19
760 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S4G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 632
