주요 콘텐츠로 건너뛰기
Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement
필요한 것
  1. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement, Hard Drive: 1 단계, 이미지 1개 중 1개
    • First you will need to turn the laptop upside down.
  2. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pushing the switch to the left and removing the battery from its slot.
  3. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 3 단계, 이미지 1개 중 1개
    • Unscrew the three 3mm screws on the compartment underneath the battery.
  4. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 3mm screws on the lowest compartment.
  5. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Metal Spudger remove the panel. Underneath is where the hard drive is connected .
  6. Compaq Presario CQ62-215dx Hard Drive Upgrade and Replacement: 6 단계, 이미지 1개 중 1개
    • This is where you detach your old hard drive and replace with the new component.
결론
작성자
2다른 기여자 명과 함께
Breana Thibodeaux
회원 가입일: 03/24/19
760 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S4G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 17
전체 시간: 485
