주요 콘텐츠로 건너뛰기
Compaq Presario CQ62-215dx RAM Replacement
필요한 것
  1. Compaq Presario CQ62-215dx RAM Replacement, RAM: 1 단계, 이미지 1개 중 1개
    • lay the laptop upside down.
  2. Compaq Presario CQ62-215dx RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pushing the lock to the left and lifting the battery from its socket.
  3. Compaq Presario CQ62-215dx RAM Replacement: 3 단계, 이미지 1개 중 1개
    • Once the battery is out, locate a panel that is underneath the battery compartment and unscrew the three 3mm screws with a Philips screwdriver.
  4. Compaq Presario CQ62-215dx RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Once removed, you should have something like in this picture. Locate the current RAM.
  5. Compaq Presario CQ62-215dx RAM Replacement: 5 단계, 이미지 1개 중 1개
    • To remove the RAM, start by lifting up the first card. Grab each side of the card with two fingers as shown in the picture and pull gently until it is removed from its slot.
  6. Compaq Presario CQ62-215dx RAM Replacement: 6 단계, 이미지 1개 중 1개
    • Insert your new RAM replacement into the slot where the old one was removed. Push until you hear a small click.
  7. Compaq Presario CQ62-215dx RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Push the card downward into the compartment until you hear another clicking sound.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Breana Thibodeaux
회원 가입일: 03/24/19
760 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019 회원
UMASSD-VALLIERE-S19S4G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 12
전체 시간: 641
