주요 콘텐츠로 건너뛰기
Compaq Presario V2414NR Keyboard Replacement
필요한 것
  1. Compaq Presario V2414NR Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Keyboard Replacement: 2 단계, 이미지 1/2 Compaq Presario V2414NR Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Keyboard Replacement, Optical Drive: 3 단계, 이미지 1/2 Compaq Presario V2414NR Keyboard Replacement, Optical Drive: 3 단계, 이미지 2/2
    • On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
    • The Drive will pop a short way out of the computer.
  4. Compaq Presario V2414NR Keyboard Replacement: 4 단계, 이미지 1/3 Compaq Presario V2414NR Keyboard Replacement: 4 단계, 이미지 2/3 Compaq Presario V2414NR Keyboard Replacement: 4 단계, 이미지 3/3
    • Remove the 7mm Phillips #1 screw that secures the optical drive to the computer.
    • Grip the sides of the Optical Drive and slide it out until it is completely removed from the computer.
    • When reassembling, slide the optical drive straight in until it clicks.
  5. Compaq Presario V2414NR Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Remove the two 4mm Philips #1 screws that secure the switch cover to the computer.
    • Turn the computer display-side up with the front panel toward you.
    • Open the computer display as far as possible.
  6. Compaq Presario V2414NR Keyboard Replacement: 6 단계, 이미지 1/1
    • Insert a plastic opening tool into the slots located behind the [F5] key and lift the front edge of the switch cover until it disengages from the computer.
    • Insert a plastic opening tool into the slots located behind the [Insert] key and lift the front edge of the switch cover until it disengages from the computer.
    • Remove the switch cover.
  7. Compaq Presario V2414NR Keyboard Replacement: 7 단계, 이미지 1/3 Compaq Presario V2414NR Keyboard Replacement: 7 단계, 이미지 2/3 Compaq Presario V2414NR Keyboard Replacement: 7 단계, 이미지 3/3
    • Remove the four 3mm Phillips #1 screws that secure the keyboard to the computer.
    • Swing the rear edge of the keyboard up and forward until it rests on the palm rest.
  8. Compaq Presario V2414NR Keyboard Replacement: 8 단계, 이미지 1/1
    • Use your fingernails or two plastic opening tools to push the white portion of the ZIF connector towards the hinge of the computer.
    • Remove the ribbon cable from the ZIF connector.
    • Remove the keyboard.
결론
Rylie Schmidt
회원 가입일: 04/19/15
765 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 287
