주요 콘텐츠로 건너뛰기
Compaq Presario V2414NR RAM Replacement
필요한 것
  1. Compaq Presario V2414NR RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR RAM Replacement: 2 단계, 이미지 1/2 Compaq Presario V2414NR RAM Replacement: 2 단계, 이미지 2/2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR RAM Replacement, RAM Cover: 3 단계, 이미지 1/2 Compaq Presario V2414NR RAM Replacement, RAM Cover: 3 단계, 이미지 2/2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR RAM Replacement, RAM: 4 단계, 이미지 1/2 Compaq Presario V2414NR RAM Replacement, RAM: 4 단계, 이미지 2/2
    • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
    • Pull the module out of the socket at the same angle it is now oriented.
    • Repeat these steps to remove the second memory module.
    • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
결론
Rylie Schmidt
회원 가입일: 04/19/15
765 평판
안내서 7개 작성하였습니다
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S2G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 239
