주요 콘텐츠로 건너뛰기
Compaq Presario v2000 Hard drive Replacement
필요한 것
  1. Compaq Presario v2000 Hard drive Replacement, Hard drive: 1 단계, 이미지 1/1
    • Remove the battery before starting
  2. Compaq Presario v2000 Hard drive Replacement: 2 단계, 이미지 1/2 Compaq Presario v2000 Hard drive Replacement: 2 단계, 이미지 2/2
    • Loosen the two screw for the hard drive cover
    • The screws will stay attached the the cover
    • Lift the cover from the left side and remove
  3. Compaq Presario v2000 Hard drive Replacement: 3 단계, 이미지 1/2 Compaq Presario v2000 Hard drive Replacement: 3 단계, 이미지 2/2
    • Lift the black pull tab on the hard drive
    • Lift the drive straight up out of the laptop
  4. Compaq Presario v2000 Hard drive Replacement: 4 단계, 이미지 1/2 Compaq Presario v2000 Hard drive Replacement: 4 단계, 이미지 2/2
    • Remove the four screws on the sides of the drive (two on each side)
    • Remove the hard drive from the caddy
  5. Compaq Presario v2000 Hard drive Replacement: 5 단계, 이미지 1/1
    • Pull the IDE connecter straight off the drive
    • Be sure to pull the connecter off straight so as not to bend the hard drive IDE pins
결론
다른 4명이 해당 안내서를 완성하였습니다.
Andrew
회원 가입일: 05/08/10
1,311 평판
안내서 5개 작성하였습니다
댓글 한 개
Perfect instructions....easy directions even for a computer dunce like me...
John Platania - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 31
전체 시간: 9,890
