주요 콘텐츠로 건너뛰기
Compaq Presario v2000 RAM Replacement
필요한 것
  1. Compaq Presario v2000 RAM Replacement, Removing the RAM cover: 1 단계, 이미지 2개 중 1개 Compaq Presario v2000 RAM Replacement, Removing the RAM cover: 1 단계, 이미지 2개 중 2개
    • Loosen the 2 Phillips screws with RAM icons above them. Don’t worry if the screws won’t come out, as they’re attached to the door.
    • Lift the RAM door up and away.
  2. Compaq Presario v2000 RAM Replacement, Removing the existing RAM: 2 단계, 이미지 3개 중 1개 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: 2 단계, 이미지 3개 중 2개 Compaq Presario v2000 RAM Replacement, Removing the existing RAM: 2 단계, 이미지 3개 중 3개
    • There are two metal clips holding both RAM modules in place.
    • To unclip them, push them both outwards from the RAM stick with your fingers until it pops out and sticks up at an angle.
    • Pull the stick of RAM out.
    • Repeat the last 3 steps for the bottom RAM stick.
  3. Compaq Presario v2000 RAM Replacement, Installing the new RAM: 3 단계, 이미지 2개 중 1개 Compaq Presario v2000 RAM Replacement, Installing the new RAM: 3 단계, 이미지 2개 중 2개
    • Start at the bottom slot. Insert the new RAM at the same angle the previous RAM popped out at.
    • Push the RAM in until a click is heard.
    • Repeat the last 2 steps for the top slot.
  4. Compaq Presario v2000 RAM Replacement, Reinstalling the RAM cover: 4 단계, 이미지 1개 중 1개
    • Repeat the first part of this guide to reinstall the RAM door.
결론
If you encounter problems after installing new RAM, redo this guide, or follow a RAM troubleshooting guide.
작성자
1다른 기여자 명과 함께
Viscous
회원 가입일: 02/02/24
381 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 279
