이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
필요한 것
Flip the laptop over and open the display to start removing the keyboard
Slide a small flat blade screwdriver between the insert and delete keys and lever the button board cover off
Remove the four keyboard screws (dark coloured 4mm screws)
Lift up the keyboard, but beware of the cable underneath still to be removed
Loosen the socket for the keyboard cable and remove the keyboard
Remove the left side of the motherboard first. It may be necessary to bent the case a little to get the firewire and USB port away from the case
Pull on the middle of the board next, angling up to clear the front audio jacks from the case
Pull the board away from the right side of the case
To reassemble your device, follow these instructions in reverse order. See special reassembly notes in steps 10 and 12.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
How to clean the fan cooler? do i have to disassemble it whole or can i just blow it from the outside, no tools?
