이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loosen the two screws of the hard drive cover
Remove the cover, then pull straight up on the pull tab to remove the hard drive
Loosen the two screws on the ram cover and remove
Loosen the one screw on the wireless card cover and remove
Remove 16 bottom cover screws (dark coloured 6mm screws)
Remove 5 screws from inside the battery bay (silver coloured 4mm screws)
Using a small flat blade screwdriver pop off the wireless aerial connectors from the wireless card
Unroute the cables from the bottom of the case
Slide out the dvd drive
Flip the laptop over and open the display to start removing the keyboard
Slide a small flat blade screwdriver between the insert and delete keys and lever the button board cover off
Remove the four keyboard screws (dark coloured 4mm screws)
Lift up the keyboard, but beware of the cable underneath still to be removed
Loosen the socket for the keyboard cable and remove the keyboard
Remove the display cable connector by lifting it straight up
Un-route the wireless aerial cables from the top cover
Remove the four display screws (dark coloured 5mm screws). Lift the display up and off
Flip the laptop over and grip the bottom case where the dvd drive used to be
Lift off the bottom case
Remove two screws from the s-video/usb board (silver coloured 4mm screws)
Lift the board from the right hand side
Remove the speaker cable and lift out the speaker module
Use a flat blade screw driver to loosen the button board connecter
Push the two wireless card arms outwards to remove the wireless card
Remove the four screws holding the mother board in place (silver coloured 4mm screws)
Remove the left side of the motherboard first. It may be necessary to bent the case a little to get the firewire and USB port away from the case
Pull on the middle of the board next, angling up to clear the front audio jacks from the case
Pull the board away from the right side of the case
Remove the three screws holding the heatsink to the mother board (silver coloured 4mm screws)
Remove the heatsink fan connecter
Lift the heatsink off the board
Use a flat blade screwdriver to turn the CPU lock and remove the CPU
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
How to clean the fan cooler? do i have to disassemble it whole or can i just blow it from the outside, no tools?
