주요 콘텐츠로 건너뛰기
Compaq iPAQ Pocket PC 3830 Battery Replacement
필요한 것
  1. Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: 1 단계, 이미지 1/2 Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: 1 단계, 이미지 2/2
    • Remove the four 0.8 mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Battery Replacement: 2 단계, 이미지 1/1
    • Detach the yellow wire from comb that is attached to the battery.
  3. Compaq iPAQ Pocket PC 3830 Battery Replacement: 3 단계, 이미지 1/1
    • The yellow wire is removed from the comb attached to the battery.
  4. Compaq iPAQ Pocket PC 3830 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery using tweezers from back cover.
  5. Compaq iPAQ Pocket PC 3830 Battery Replacement: 5 단계, 이미지 1/1
    • Detach the battery from back cover.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Sedina Cavcic
회원 가입일: 09/05/14
464 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G1
3 회원들
안내서 7개 작성하였습니다
댓글 2개
One question; Where can I get a new battery????
Every place I have looked have a smaller batter,  not like the one you show.
Stephen
oharasc85@gmail.com
Stephen O'Hara - 답글
we are in need of battery
Danionics DLP 305590
Quantity : 02 Nos.
Please send us the lowest estimate.
Mail ID: electronics@pmtpims.org
ELECTRONICS1 PIMS - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 38
전체 시간: 3,151
