주요 콘텐츠로 건너뛰기
Compaq iPAQ Pocket PC 3830 Motherboard Replacement
필요한 것
  1. Compaq iPAQ Pocket PC 3830 Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Compaq iPAQ Pocket PC 3830 Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove the four 0.8mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the two screws on top of the motherboard and the two screws on bottom of motherboard
  3. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 3 단계, 이미지 1/2 Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 3 단계, 이미지 2/2
    • Detach the wires from their combs on the motherboard.
  4. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 4 단계, 이미지 1/1
    • Detach from comb that is located on motherboard.
  5. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 5 단계, 이미지 1/2 Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the small piece from the motherboard.
  6. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 6 단계, 이미지 1/1
    • Use tweezers to remove last piece from the comb on the motherboard.
  7. Compaq iPAQ Pocket PC 3830 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the motherboard by simply lifting it.
결론
Sedina Cavcic
회원 가입일: 09/05/14
464 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-1, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 9
전체 시간: 508
