주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Macintosh Color Classic 수리는 저희 서비스 설명서를 사용하십시오.
  1. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside), Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 1 단계, 이미지 1/1
    • My Macintosh Color Classic running under MacOS 7.6 some days before it died
  2. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 2 단계, 이미지 1/1
    • Machine completely emptied
  3. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 3 단계, 이미지 1/1
    • all original components…
  4. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 4 단계, 이미지 1/1
    • ...were replaced with the new ones
  5. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 5 단계, 이미지 1/1
    • Testing the new HDMI 8” LCD screen.
  6. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 6 단계, 이미지 1/1
    • The chassis and the power supply board were cleaned up and adapted for fitting the new components.
  7. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 7 단계, 이미지 1/1
    • Installing the new screen
  8. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 8 단계, 이미지 1/1
    • Closing the back case
  9. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 9 단계, 이미지 1/1
    • Sliding in and connecting the MacMini 2014
  10. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 10 단계, 이미지 1/1
    • Closing the clip-in backplane
  11. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 11 단계, 이미지 1/1
    • Plugging in the computer
  12. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 12 단계, 이미지 1/1
    • Starting the computer
  13. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 13 단계, 이미지 1/1
    • Macintosh Color Classic running under MacOS Mojave
  14. Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 14 단계, 이미지 1/3 Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 14 단계, 이미지 2/3 Completely Revamped Macintosh Color Classic for its 25th Anniversary (Mac Mini inside): 14 단계, 이미지 3/3
    • Insert wisdom here.
Roberto
회원 가입일: 06/08/17
245 평판
안내서 1개 작성함
댓글 12개
Wow, such a clean built. Thanks for sharing!
Luke - 답글
La pantalla es lo que mas temor da retirar si es igual a las de la emac y imacs, me gustaría haberlo hecho con la que me dañaron en un taller, no la guarde y tire la basura, en fin jamas se sabe lo que la tecnología nueva nos permite hacer con las viejas carcazas, debe ser grato ver la cara de la gente que te ve trabajar en ella con teclado y ratón inalámbricos.
javiersconde - 답글
Do you have a more detailed breakdown, including exact parts used. I have one of these Macs and it has died. The sentimental value is huge so doing to it what you did to yours is an awesome idea. Thanks
Nathan Fletcher - 답글
Sorry, I haven’t more details of the breakdown. The most difficult part was to clean up the power supply board and to saw parts of the plastic chassis to fit the MacMini inside. The parts I kept from the original machine are the chassis, the power supply board and the framework that sustained the original screen.
Roberto -
Roberto, what size is the fan? 60x25mm? And can you remove the stock fan from that metal housing so as to replace it with a quieter modern version? Thanks.
James Wages - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 4,185
