소개
Follow this guide to conduct a cylinder compression test on a 2019 Echo Power Pruner model PPT-2620.
필요한 것
Use a 5/8-inch spark plug socket to remove the spark plug from the engine.
Check if the spark plug is fouled and replace it if necessary.
Follow the instruction provided with your compression test kit to connect a compression tester to the cylinder.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
