주요 콘텐츠로 건너뛰기
Computer King Muffin Kinder 7 Screen Replacement
필요한 것
  1. Computer King Muffin Kinder 7 Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Computer King Muffin Kinder 7 Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Screen Replacement: 3 단계, 이미지 2개 중 1개 Computer King Muffin Kinder 7 Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Screen Replacement: 5 단계, 이미지 2개 중 1개 Computer King Muffin Kinder 7 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • There will be a black strip connected to the screen.
    • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
  6. Computer King Muffin Kinder 7 Screen Replacement: 6 단계, 이미지 3개 중 1개 Computer King Muffin Kinder 7 Screen Replacement: 6 단계, 이미지 3개 중 2개 Computer King Muffin Kinder 7 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
    • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
  7. Computer King Muffin Kinder 7 Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the two ribbon cables out so that they are no longer connected to the logic board.
  8. Computer King Muffin Kinder 7 Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Lift up the logic board and black plastic so that they are no longer covering the screen
    • Lift out the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Katherine
회원 가입일: 01/22/15
439 평판
안내서 3개를 작성함
UWT Liner: Group 2 UWT Liner: Group 2 회원
Community
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 538
