주요 콘텐츠로 건너뛰기
Conair Infiniti PRO Curling Iron Power Cord Replacement
필요한 것
  1. Conair Infiniti PRO Curling Iron Power Cord Replacement, Housing: 1 단계, 이미지 1개 중 1개
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Power Cord Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Power Cord Replacement: 3 단계, 이미지 3개 중 1개 Conair Infiniti PRO Curling Iron Power Cord Replacement: 3 단계, 이미지 3개 중 2개 Conair Infiniti PRO Curling Iron Power Cord Replacement: 3 단계, 이미지 3개 중 3개
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Power Cord Replacement, Power Cord: 4 단계, 이미지 1개 중 1개
    • Pull power chord out.
결론
작성자
3다른 기여자 명과 함께
Jonathon Bruer
회원 가입일: 11/09/17
607 평판
안내서 5개를 작성함
IUPUI, Team S7-G5, Baechle Fall 2017 IUPUI, Team S7-G5, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S7G5
3 회원들
안내서 5개를 작성함
3가이드 댓글
Where do I find the cords needed for the repair I've looked everywhere
John Cornelison - 답글
I also couldn’t find the needed cord.
C vd Linden - 답글
I'm surprised that anyone won a prize for these instructions when they've left out the source of their replacement cord.
The replacement power cords are apparently mythical by this time, and I think that Global Beauty bit the dust as well. But if you disassemble the swivel (the part with the sliding electrical contacts) you may notice that the "male" portion of the swivel assembly looks like you could dig or drill out the broken wires and solder in the inner wires of the existing power cord, which will render the cord a bit shorter. You'll also need some sort of flexible strain relief, and I think that the old one could be cut off the discarded portion of the old power cord and glued (with cyanoacrylate, or Super Glue) back onto the cord.
Mark Kinsler - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 30
전체 시간: 3,037
