주요 콘텐츠로 건너뛰기
Conair Infiniti PRO Spin Air Brush Circuit Board Replacement
필요한 것
  1. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1/1
    • Look for the black screw covers near the top of the brush. Take the covers off with flat head screw driver.
  2. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the screws that secure the brush head.
  3. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 3 단계, 이미지 1/1
    • Gently take off the brush top.
  4. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 4 단계, 이미지 1/1
    • Take out the black gear by pulling up.
  5. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 5 단계, 이미지 1/1
    • Take the top of air filter off.
  6. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 6 단계, 이미지 1/1
    • Use flat head screwdriver to pop off the bottom air filter.
  7. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 7 단계, 이미지 1/1
    • Gently use a flat head screw driver to take of the black cover, covering the plastic shell.
  8. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 8 단계, 이미지 1/1
    • Using your flat head screwdriver to go along the seams of the plastic shell till the shell pops apart.
  9. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 9 단계, 이미지 1/1
    • Then take the switch cover and buttons off.
  10. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 10 단계, 이미지 1/1
    • Then take your Philips screw driver (ph1 size head) and unscrew the circuit board. The screw is located in the middle of the board.
  11. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 11 단계, 이미지 1/1
    • Remove the black heater cover by sliding it off.
    • Desolder each of the four connections, and remove the circuit board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
andrew shirley
회원 가입일: 08/23/17
337 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Freund Fall 2017 IUPUI, Team S1-G3, Freund Fall 2017 회원
IUPUI-FREUND-F17S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 56
전체 시간: 672
