주요 콘텐츠로 건너뛰기
Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement
필요한 것
  1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Back Panel: 1 단계, 이미지 1/1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 2 단계, 이미지 1/2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 2 단계, 이미지 2/2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 3 단계, 이미지 1/3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 3 단계, 이미지 2/3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 3 단계, 이미지 3/3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: 4 단계, 이미지 1/2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: 4 단계, 이미지 2/2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 5 단계, 이미지 1/3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 5 단계, 이미지 2/3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 5 단계, 이미지 3/3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Timothy Lo
회원 가입일: 04/22/14
1,172 평판
안내서 7개 작성하였습니다
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G58
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 41
전체 시간: 7,316
