주요 콘텐츠로 건너뛰기
Connect Four Electronic Handheld Battery Compartment Replacement
필요한 것
  1. Connect Four Electronic Handheld Battery Compartment Replacement, Ensure the device is off.: 1 단계, 이미지 1/1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: 2 단계, 이미지 1/2 Connect Four Electronic Handheld Battery Compartment Replacement, Removing the battery casing.: 2 단계, 이미지 2/2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
결론
Kamaryn
회원 가입일: 10/22/14
225 평판
안내서 2개 작성하였습니다
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G11
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 131
