주요 콘텐츠로 건너뛰기
Connect Four Electronic Handheld Buttons Replacement
필요한 것
  1. Connect Four Electronic Handheld Buttons Replacement, Ensure the device is off.: 1 단계, 이미지 1개 중 1개
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: 2 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: 2 단계, 이미지 2개 중 2개
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: 3 단계, 이미지 2개 중 1개 Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: 3 단계, 이미지 2개 중 2개
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
  4. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: 4 단계, 이미지 3개 중 1개 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: 4 단계, 이미지 3개 중 2개 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: 4 단계, 이미지 3개 중 3개
    • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
    • Using a spudger, lever the circuit board just enough to where you can easily access the button sheet.
  5. Connect Four Electronic Handheld Buttons Replacement, Removing/ Replacing the Button Sheet: 5 단계, 이미지 1개 중 1개
    • Take out the button sheet, and replace it with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Julia Wyder
회원 가입일: 10/22/14
110 평판
안내서 1개를 작성함
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 회원
BU-WILLIAMS-F14S8G11
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 406
