주요 콘텐츠로 건너뛰기
Convert a 360 (Fat) hard drive into a 360 S hard drive
필요한 것
  1. Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: 1 단계, 이미지 1/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: 1 단계, 이미지 2/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Remove the bottom screws: 1 단계, 이미지 3/3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disassembly tip: 2 단계, 이미지 1/1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: 3 단계, 이미지 1/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: 3 단계, 이미지 2/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Open the drive: 3 단계, 이미지 3/3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: 4 단계, 이미지 1/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: 4 단계, 이미지 2/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Disconnect and remove the hard drive: 4 단계, 이미지 3/3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
  5. Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: 5 단계, 이미지 1/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: 5 단계, 이미지 2/3 Convert a 360 (Fat) hard drive into a 360 S hard drive, Install the hard drive into the new enclosure: 5 단계, 이미지 3/3
    • If you do not use an official hard drive, you will need a WD hard drive, the Xbox hard drive sector security file and HDDhackr to partition the drive. Partition 2 must be restored manually.
    • After removing the drive from the old enclosure, open the new enclosure.
    • Put the drive in the enclosure label side up. Space may need to be added for 7mm drives.
    • Close the enclosure and install it in your console.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
88,911 평판
안내서 49개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,540개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 53
전체 시간: 3,494
