주요 콘텐츠로 건너뛰기
Cooler Master Laptop Fan Replacement
필요한 것
  1. Cooler Master Laptop Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
    • Never try to open the cooler while plugged in.
  2. Cooler Master Laptop Fan Replacement: 2 단계, 이미지 1/1
    • Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
  3. Cooler Master Laptop Fan Replacement: 3 단계, 이미지 1/3 Cooler Master Laptop Fan Replacement: 3 단계, 이미지 2/3 Cooler Master Laptop Fan Replacement: 3 단계, 이미지 3/3
    • Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
  4. Cooler Master Laptop Fan Replacement: 4 단계, 이미지 1/2 Cooler Master Laptop Fan Replacement: 4 단계, 이미지 2/2
    • Remove the cover and expose the inside of the Cooler.
  5. Cooler Master Laptop Fan Replacement: 5 단계, 이미지 1/2 Cooler Master Laptop Fan Replacement: 5 단계, 이미지 2/2
    • Unplug the power cable to the fan.
    • Make sure not to apply too much force and disconnect the wires to the device.
  6. Cooler Master Laptop Fan Replacement: 6 단계, 이미지 1/2 Cooler Master Laptop Fan Replacement: 6 단계, 이미지 2/2
    • On the bottom of the base locate the screw holes under the sticker on the base.
    • Unscrew the three fan screws.
  7. Cooler Master Laptop Fan Replacement: 7 단계, 이미지 1/1
    • Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
  8. Cooler Master Laptop Fan Replacement: 8 단계, 이미지 1/1
    • Apply a small amount of thermal compound to the base where the fan sets.
    • Make sure to apply thermal compound to keep the fan from overheating and damaging the base.
  9. Cooler Master Laptop Fan Replacement: 9 단계, 이미지 1/2 Cooler Master Laptop Fan Replacement: 9 단계, 이미지 2/2
    • Connect power cable for the fan and place the cables back in their slots.
  10. Cooler Master Laptop Fan Replacement: 10 단계, 이미지 1/2 Cooler Master Laptop Fan Replacement: 10 단계, 이미지 2/2
    • Screw fan back onto base.
  11. Cooler Master Laptop Fan Replacement: 11 단계, 이미지 1/1
    • Place cover back on base.
  12. Cooler Master Laptop Fan Replacement: 12 단계, 이미지 1/1
    • Fold all metal flaps back to hold cover on base.
  13. Cooler Master Laptop Fan Replacement: 13 단계, 이미지 1/1
    • Flip it over and it's finished.
결론
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
다른 2명이 해당 안내서를 완성하였습니다.
Britton Williams
회원 가입일: 09/26/18
271 평판
안내서 1개 작성함
댓글 2개
Hi there,
I’ve got a Targus Lap Chill Matt (Laptop Cooling Pad 15 - 17" Laptops) but the USB port had worn out and require a new replacement. Does anyone have any examples on how to replace the UBS port from a Laptop Cooler Pad?
Thanks!
rolly - 답글
Hi,
Just wanted to say huge thanks to you for this guideline! I have a Cooler Master Notepal L1 and the fan kept making noises. But now it works totally fine after I was able to open the cover.
Thanks again!
//Parisa
Parisa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 30
30일 전: 87
전체 시간: 5,512
