주요 콘텐츠로 건너뛰기
Coolpad 3300A Disassembly
필요한 것
  1. Coolpad 3300A Disassembly, Coolpad 3300A Disassembly: 1 단계, 이미지 1/1
    • After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
  2. Coolpad 3300A Disassembly: 2 단계, 이미지 1/3 Coolpad 3300A Disassembly: 2 단계, 이미지 2/3 Coolpad 3300A Disassembly: 2 단계, 이미지 3/3
    • Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
  3. Coolpad 3300A Disassembly: 3 단계, 이미지 1/3 Coolpad 3300A Disassembly: 3 단계, 이미지 2/3 Coolpad 3300A Disassembly: 3 단계, 이미지 3/3
    • Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
  4. Coolpad 3300A Disassembly: 4 단계, 이미지 1/1
    • After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Riley Casteel
회원 가입일: 03/26/18
395 평판
안내서 1개 작성함
IUPUI, Team S1-G3, Harley Spring 2018 IUPUI, Team S1-G3, Harley Spring 2018 회원
IUPUI-HARLEY-S18S1G3
6 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 1,110
