소개
Is your device not properly turning on or charging? Consider using this guide to replace the battery in your phone.
필요한 것
Turn the phone with the back cover facing towards you.
Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
Find the gap on the bottom of the battery.
With a tool or with your hands, pull the battery upward and set it aside safely.
다른 한 분이 해당 안내서를 완성하였습니다.
