주요 콘텐츠로 건너뛰기
Coolpad Defiant Battery Replacement
필요한 것
  1. Coolpad Defiant Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Coolpad Defiant Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: 2 단계, 이미지 1/1
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnny Boland
회원 가입일: 09/21/18
500 평판
안내서 3개 작성하였습니다
University of North Texas, Team S5-G6, Thompson Fall 2018 University of North Texas, Team S5-G6, Thompson Fall 2018 회원
UNT-THOMPSON-F18S5G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,437
