주요 콘텐츠로 건너뛰기
Coolpad Defiant Rear Camera Replacement
필요한 것
  1. Coolpad Defiant Rear Camera Replacement, Back Cover: 1 단계, 이미지 1/2 Coolpad Defiant Rear Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Rear Camera Replacement: 2 단계, 이미지 1/1
    • Remove the back cover from your device.
  3. Coolpad Defiant Rear Camera Replacement, Battery: 3 단계, 이미지 1/1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Rear Camera Replacement, Rear Camera: 4 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Rear Camera Replacement: 5 단계, 이미지 1/2 Coolpad Defiant Rear Camera Replacement: 5 단계, 이미지 2/2
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Rear Camera Replacement: 6 단계, 이미지 1/1
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Rear Camera Replacement: 7 단계, 이미지 1/3 Coolpad Defiant Rear Camera Replacement: 7 단계, 이미지 2/3 Coolpad Defiant Rear Camera Replacement: 7 단계, 이미지 3/3
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Rear Camera Replacement: 8 단계, 이미지 1/3 Coolpad Defiant Rear Camera Replacement: 8 단계, 이미지 2/3 Coolpad Defiant Rear Camera Replacement: 8 단계, 이미지 3/3
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Rear Camera Replacement: 9 단계, 이미지 1/1
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
결론
Johnny Boland
회원 가입일: 09/21/18
500 평판
안내서 3개 작성하였습니다
University of North Texas, Team S5-G6, Thompson Fall 2018 University of North Texas, Team S5-G6, Thompson Fall 2018 회원
UNT-THOMPSON-F18S5G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 267
