주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Coolpad Defiant Screen Replacement
필요한 것
    1. Coolpad Defiant Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Coolpad Defiant Screen Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
      • Turn the phone with the back cover facing towards you.
      • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
      • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
      댓글 쓰기
    2. Coolpad Defiant Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the back cover from your device.
      댓글 쓰기
    1. Coolpad Defiant Screen Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Find the gap on the bottom of the battery.
      • With a tool or with your hands, pull the battery upward and set it aside safely.
      • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
      • Be careful with old or damaged batteries and dispose of it appropriately
      댓글 쓰기
    1. Coolpad Defiant Screen Replacement, Rear Camera: 4 단계, 이미지 1개 중 1개
      • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
      댓글 쓰기
    2. Coolpad Defiant Screen Replacement: 5 단계, 이미지 2개 중 1개 Coolpad Defiant Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Using either a plastic pry tool or your hands, pry the plastic cover away.
      댓글 쓰기
    3. Coolpad Defiant Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
      댓글 쓰기
    4. Coolpad Defiant Screen Replacement: 7 단계, 이미지 3개 중 1개 Coolpad Defiant Screen Replacement: 7 단계, 이미지 3개 중 2개 Coolpad Defiant Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
      • Using the same tool, remove the antenna from the bottom logic board
      댓글 쓰기
    5. Coolpad Defiant Screen Replacement: 8 단계, 이미지 3개 중 1개 Coolpad Defiant Screen Replacement: 8 단계, 이미지 3개 중 2개 Coolpad Defiant Screen Replacement: 8 단계, 이미지 3개 중 3개
      • Carefully pull up on the upper logic board starting from the top and pull it straight up.
      • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
      댓글 쓰기
    6. Coolpad Defiant Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
      • Pull straight up on the camera and it will slide out of the logic board.
      댓글 쓰기
    1. Coolpad Defiant Screen Replacement, Screen: 10 단계, 이미지 2개 중 1개 Coolpad Defiant Screen Replacement, Screen: 10 단계, 이미지 2개 중 2개
      • Using the plastic pry tool, remove the lower logic board, starting with the removal of the vibrator and working across the board.
      • The board is held down by adhesives, so force is required to remove it.
      • Since the board is fragile, be careful when removing the board.
      댓글 쓰기
    2. Coolpad Defiant Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Place the suction cup tool on the bottom left corner of the screen.
      댓글 쓰기
    3. Coolpad Defiant Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Pull straight up on the suction cup to pop the screen off.
      • Some heat may need to be applied to loosen the adhesive. Use a hair dryer or heat gun. This device was easy pulled apart without heat tho.
      • Be sure to lift the bottom of the screen up. Be careful of the cables on the top of the screen.
      댓글 쓰기
    4. Coolpad Defiant Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Once the screen is free from the adhesive, slide the flex cable through the middle chassis assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnny Boland
회원 가입일: 09/21/18
535 평판
안내서 3개를 작성함
1가이드 댓글
I never even heard of this website till today I think it's awesome I'm wondering is there like a program or a thing set up to where I can mail my phone and pay someone to do it for me because I'm like extremely heavy-handed and I'm clumsy I trip up steps so I know and there's a 13 directions I seen the word careful a whole lot and pull easy and I've already have an anxiety just thinking about me doing it let alone actually doing it so is there any way someone can help me
Crystal Tyson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 37
전체 시간: 3,708
