소개
Have you tried everything and your camera just won't turn on? No worries! This guide will show you how to successfully remove your battery.
필요한 것
Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
Next, remove the 2mm screw from the right side.
Lastly, remove the 3mm screw from the bottom of the camera.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
