주요 콘텐츠로 건너뛰기
Coolpix S01 USB Cover Replacement
필요한 것
  1. Coolpix S01 USB Cover Replacement, USB Cover: 1 단계, 이미지 1/3 Coolpix S01 USB Cover Replacement, USB Cover: 1 단계, 이미지 2/3 Coolpix S01 USB Cover Replacement, USB Cover: 1 단계, 이미지 3/3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
    • Next remove the 2 mm screw from the right side of the camera.
  2. Coolpix S01 USB Cover Replacement: 2 단계, 이미지 1/3 Coolpix S01 USB Cover Replacement: 2 단계, 이미지 2/3 Coolpix S01 USB Cover Replacement: 2 단계, 이미지 3/3
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 USB Cover Replacement: 3 단계, 이미지 1/3 Coolpix S01 USB Cover Replacement: 3 단계, 이미지 2/3 Coolpix S01 USB Cover Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • On the bottom of the camera, locate the USB port.
    • Gently slide the USB cover off of the camera with your fingers or tweezers.
    • You can replace the USB cover by purchasing one from a local electronics store or online at iFixit.com.
결론
Fernando Ochoa
회원 가입일: 10/13/15
113 평판
안내서 1개 작성함
Sam Houston State, Team 2-3, Blackburne Fall 2015 Sam Houston State, Team 2-3, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 324
