소개
Broken zoom trigger? No problem! If you own a Nikon Coolpix digital camera and are experiencing a jammed zoom trigger or a zoom trigger that just won't work, this guide will surely help.
필요한 것
Before starting, make sure the camera is powered off.
Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
Next, remove the 2mm screw from the right side.
Lastly, remove the 3mm screw from the bottom of the camera.
거의 끝나갑니다!
결론
