주요 콘텐츠로 건너뛰기
Copic Marker Nib Replacement
필요한 것
  1. Copic Marker Nib Replacement, Copic Marker Nib: 1 단계, 이미지 1/1
    • Place a few paper towels on the surface of your workspace to protect it from ink spills.
  2. Copic Marker Nib Replacement: 2 단계, 이미지 1/1
    • Remove the cap from the marker to expose the nib.
  3. Copic Marker Nib Replacement: 3 단계, 이미지 1/3 Copic Marker Nib Replacement: 3 단계, 이미지 2/3 Copic Marker Nib Replacement: 3 단계, 이미지 3/3
    • Gently tug out the thicker part of the nib with the tweezer.
  4. Copic Marker Nib Replacement: 4 단계, 이미지 1/2 Copic Marker Nib Replacement: 4 단계, 이미지 2/2
    • Remove the cap of the ink bottle and tilt the container to begin filling the marker.
    • Avoid forcibly squeezing the ink bottle.
    • Slowly fill the pen until it is approximately 3/4ths of the way full.
  5. Copic Marker Nib Replacement: 5 단계, 이미지 1/3 Copic Marker Nib Replacement: 5 단계, 이미지 2/3 Copic Marker Nib Replacement: 5 단계, 이미지 3/3
    • Insert the flat side of the new nib facing the opening of the marker until it snaps into place.
    • Set the marker down after replacing new nib.
  6. Copic Marker Nib Replacement: 6 단계, 이미지 1/3 Copic Marker Nib Replacement: 6 단계, 이미지 2/3 Copic Marker Nib Replacement: 6 단계, 이미지 3/3
    • Wait 3 minutes for the color to spread through the nib until it is no longer white.
    • Press on the middle of the marker 3 times to insure ink is spread throughout.
    • Repeat steps 3 - 5 if the amount of ink is insufficient.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Iris Lin
회원 가입일: 04/28/17
149 평판
안내서 1개 작성함
UC Davis, Team S1-G5, Coad Spring 2017 UC Davis, Team S1-G5, Coad Spring 2017 회원
UCD-COAD-S17S1G5
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 34
전체 시간: 2,812
