소개
Use this guide to replace the strings of a Cordoba C5 classical guitar. Through regular use, guitar strings will become worn out and/or break, making string replacement a common and necessary repair for the guitar. The strings are essential for the guitar to produce the desired sound, and attaching them properly in the first place can help prevent malfunctions and promote longevity.
There are no special skills or tools required to complete this guide. For ease, complete the guide with the guitar laid on a flat surface.
필요한 것
Loosen the guitar string by turning the tuning peg in a counterclockwise direction.
Take your new nylon guitar string and feed one end into the bridge hole.
To tie the knot, hold onto the longer end of the string with your left hand and grab the end of the short string with your right hand. Wrap the end of the short string back around itself two times. The string should resemble a figure-8 pattern.
Hold down the knot on the bridge with your fingers and pull the longer end of the string with your left hand to tighten the knot.
