주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Core Assembly Removal
필요한 것
  1. Core Assembly Removal, Power down your watch: 1 단계, 이미지 1개 중 1개
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    댓글 쓰기
  2. Core Assembly Removal, Unscrew the back cover: 2 단계, 이미지 1개 중 1개
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
    댓글 쓰기
  3. Core Assembly Removal, Pry open the back cover: 3 단계, 이미지 2개 중 1개 Core Assembly Removal, Pry open the back cover: 3 단계, 이미지 2개 중 2개
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
    댓글 쓰기
  4. Core Assembly Removal, Disconnect the sensor flex cable: 4 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the sensor flex cable: 4 단계, 이미지 2개 중 2개
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    댓글 쓰기
  5. Core Assembly Removal, Remove the back cover: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
    댓글 쓰기
  6. Core Assembly Removal, Disconnect the hall sensor flex cable: 6 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the hall sensor flex cable: 6 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
    댓글 쓰기
  7. Core Assembly Removal, Disconnect the display flex cable: 7 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the display flex cable: 7 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the display flex cable.
    댓글 쓰기
  8. Core Assembly Removal, Disconnect the side buttons: 8 단계, 이미지 2개 중 1개 Core Assembly Removal, Disconnect the side buttons: 8 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the crown button flex cable.
    댓글 쓰기
  9. Core Assembly Removal, Unscrew the motherboard: 9 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
    댓글 쓰기
  10. Core Assembly Removal, Remove the motherboard: 10 단계, 이미지 3개 중 1개 Core Assembly Removal, Remove the motherboard: 10 단계, 이미지 3개 중 2개 Core Assembly Removal, Remove the motherboard: 10 단계, 이미지 3개 중 3개
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
    댓글 쓰기
  11. Core Assembly Removal, Lift the core assembly: 11 단계, 이미지 3개 중 1개 Core Assembly Removal, Lift the core assembly: 11 단계, 이미지 3개 중 2개 Core Assembly Removal, Lift the core assembly: 11 단계, 이미지 3개 중 3개
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    댓글 쓰기
  12. Core Assembly Removal, Release the core assembly: 12 단계, 이미지 2개 중 1개 Core Assembly Removal, Release the core assembly: 12 단계, 이미지 2개 중 2개
    • Thread the display flex cable through the opening in the core assembly.
    댓글 쓰기
  13. Core Assembly Removal, Remove the core assembly: 13 단계, 이미지 1개 중 1개
    • Remove the core assembly.
    댓글 쓰기
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
67,744 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 31,446개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 33
전체 시간: 1,542
