주요 콘텐츠로 건너뛰기
Corsair Katar DPI Sensor Replacement
필요한 것
  1. Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: 1 단계, 이미지 1/2 Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: 1 단계, 이미지 2/2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar DPI Sensor Replacement: 2 단계, 이미지 1/1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar DPI Sensor Replacement: 3 단계, 이미지 1/2 Corsair Katar DPI Sensor Replacement: 3 단계, 이미지 2/2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar DPI Sensor Replacement: 4 단계, 이미지 1/1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar DPI Sensor Replacement, DPI Sensor: 5 단계, 이미지 1/2 Corsair Katar DPI Sensor Replacement, DPI Sensor: 5 단계, 이미지 2/2
    • Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
  6. Corsair Katar DPI Sensor Replacement: 6 단계, 이미지 1/1
    • Lift the DPI sensor away from the mouse shell.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Margaret Loughren
회원 가입일: 07/12/18
594 평판
안내서 5개 작성하였습니다
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 회원
UWT-CARDINAL-SU18S1G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 429
