주요 콘텐츠로 건너뛰기
Corsair M55 RGB Pro Gaming Mouse Motherboard
필요한 것
  1. Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: 1 단계, 이미지 1/3 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: 1 단계, 이미지 2/3 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: 1 단계, 이미지 3/3
    • Use a spudger to gently peel off and remove the three mouse feet on the bottom of the mouse.
    • If you are not replacing the mouse feet with a new set, put them aside to replace them at the end of the repair.
  2. Corsair M55 RGB Pro Gaming Mouse Motherboard: 2 단계, 이미지 1/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 2 단계, 이미지 2/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 2 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws from the bottom of the mouse.
    • There is a cable connecting the bottom and top of the mouse.
  3. Corsair M55 RGB Pro Gaming Mouse Motherboard: 3 단계, 이미지 1/2 Corsair M55 RGB Pro Gaming Mouse Motherboard: 3 단계, 이미지 2/2
    • Use a spudger to separate the top and bottom of the mouse.
    • Don't pull them apart as they are connected by a cable connector and could become damaged.
    • Pull the PCB cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  4. Corsair M55 RGB Pro Gaming Mouse Motherboard: 4 단계, 이미지 1/2 Corsair M55 RGB Pro Gaming Mouse Motherboard: 4 단계, 이미지 2/2
    • Pull the USB pin cable away from the connector in the same direction as the individual wires are running.
  5. Corsair M55 RGB Pro Gaming Mouse Motherboard: 5 단계, 이미지 1/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 5 단계, 이미지 2/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 5 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws that secure the motherboard.
  6. Corsair M55 RGB Pro Gaming Mouse Motherboard: 6 단계, 이미지 1/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 6 단계, 이미지 2/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 6 단계, 이미지 3/3
    • Carefully lift the motherboard out of the base of the mouse by the edges.
  7. Corsair M55 RGB Pro Gaming Mouse Motherboard: 7 단계, 이미지 1/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 7 단계, 이미지 2/3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 7 단계, 이미지 3/3
    • If necessary, remove the mouse wheel by sliding it to the right.
    • It should come out of the slot easily as it's not attached.
결론
Rizza Barnwell
회원 가입일: 03/05/24
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 8-11, Grodsky Spring 2024 CSU Los Angeles, Team 8-11, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S8G11
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 38
전체 시간: 81
