주요 콘텐츠로 건너뛰기
Corsair Scimitar Mouse Wheel Replacement
필요한 것
  1. Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: 1 단계, 이미지 2개 중 1개 Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: 1 단계, 이미지 2개 중 2개
    • Heat the mouse feet with a heat gun to loosen the adhesive.
    • Pry the mouse feet off of the mouse with the metal spudger.
  2. Corsair Scimitar Mouse Wheel Replacement: 2 단계, 이미지 2개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the four 8.9 mm bottom screws with a JIS #00 screwdriver.
    • Loosen the keyslider lock with a 2.5 mm hex screw driver.
  3. Corsair Scimitar Mouse Wheel Replacement: 3 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 3 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 3 단계, 이미지 3개 중 3개
    • Pry along the seam of the mouse body to separate the top and bottom halves.
  4. Corsair Scimitar Mouse Wheel Replacement: 4 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 4 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the top cover from the mouse.
  5. Corsair Scimitar Mouse Wheel Replacement: 5 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 5 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the locking mechanism on the auxiliary switch board ribbon cable connector with a plastic spudger.
    • Pull the ribbon cable gently to disconnect from the main board.
  6. Corsair Scimitar Mouse Wheel Replacement: 6 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 6 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the locking mechanism on the Key Slider assembly ribbon cable connector with a plastic spudger.
    • Pull the Key Slider assembly ribbon cable gently to disconnect it from the main board.
  7. Corsair Scimitar Mouse Wheel Replacement: 7 단계, 이미지 2개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 7 단계, 이미지 2개 중 2개
    • Pull the Keyslider ribbon cable up and out of the plastic post.
  8. Corsair Scimitar Mouse Wheel Replacement: 8 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 8 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 8 단계, 이미지 3개 중 3개
    • Use a JIS #0 screwdriver to remove the 6 mm screw from the key slider assembly.
    • Remove the key slider assembly from the body of the mouse.
  9. Corsair Scimitar Mouse Wheel Replacement: 9 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 9 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 9 단계, 이미지 3개 중 3개
    • Disconnect the data cable from the auxiliary switch board.
  10. Corsair Scimitar Mouse Wheel Replacement: 10 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 10 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 10 단계, 이미지 3개 중 3개
    • Use a JIS #0 screwdriver to remove the two 6 mm screws from the auxiliary switch board.
    • Remove the auxiliary switch board.
  11. Corsair Scimitar Mouse Wheel Replacement: 11 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 11 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 11 단계, 이미지 3개 중 3개
    • Use a JIS #0 screwdriver to remove the three 6 mm screws from the main board to separate it from the mouse body.
  12. Corsair Scimitar Mouse Wheel Replacement: 12 단계, 이미지 2개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 12 단계, 이미지 2개 중 2개
    • Disconnect the data cable from the main board.
  13. Corsair Scimitar Mouse Wheel Replacement: 13 단계, 이미지 2개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the main board off of the body of the mouse.
  14. Corsair Scimitar Mouse Wheel Replacement: 14 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 14 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 14 단계, 이미지 3개 중 3개
    • Push the scroll wheel gently away from the rotary encoder switch to remove it.
    • Check the rotary encoder hex hole to make sure it is clear of debris.
  15. Corsair Scimitar Mouse Wheel Replacement: 15 단계, 이미지 3개 중 1개 Corsair Scimitar Mouse Wheel Replacement: 15 단계, 이미지 3개 중 2개 Corsair Scimitar Mouse Wheel Replacement: 15 단계, 이미지 3개 중 3개
    • Remove the rubber ring from the scroll wheel.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Amelia Camp
회원 가입일: 10/06/22
303 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 82
지난 30일: 346
전체 시간: 9,983
