주요 콘텐츠로 건너뛰기
Cover Panel Disassembly
필요한 것
  1. Cover Panel Disassembly, Cover Panel: 1 단계, 이미지 1/1
    • Find the mating groove running along the side of device. Use an ifixit opening tool to pry the two mating surfaces apart with a twisting motion.
    • Once the surfaces have been separated, using your fingers, pull the two surfaces apart evenly around the edge of the device.
    • During reassembly, be sure to press the two pieces together all the way around the perimeter to ensure good connection.
결론
To reassemble your device, follow these steps in reverse order.
Brock Schaffer
회원 가입일: 10/26/16
481 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-5, Baechle Fall 2016 IUPUI, Team 2-5, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S2G5
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 217
