주요 콘텐츠로 건너뛰기
Cowin E7 Ear Cushion Replacement
필요한 것
  1. Cowin E7 Ear Cushion Replacement, Ear Cushion: 1 단계, 이미지 1/1
    • Inspect the seal around the edge of each ear cushion for damage or instability.
    • Make note of which ear cushion needs to be replaced.
  2. Cowin E7 Ear Cushion Replacement: 2 단계, 이미지 1/1
    • Firmly grasp the ear cushion on one side and pull up.
    • The ear cushion is only attached by a few spots of glue, so it should not take much force to remove.
  3. Cowin E7 Ear Cushion Replacement: 3 단계, 이미지 1/1
    • Spread multipurpose glue around the edge of the seal.
    • Keep in mind that the more glue you use, the harder it will be to remove the ear cushions again.
    • Place the replacement ear cushions where the damaged cushions were.
    • Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
Jacob Burrer
회원 가입일: 03/26/22
439 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-2, Mellen Spring 2022 UMass Dartmouth, Team 2-2, Mellen Spring 2022 회원
UMASSD-MELLEN-S22S2G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 45
30일 전: 203
전체 시간: 4,830
