소개
This is a common enough problem that I felt it warranted a repair guide- in addition, I wanted my trusted circular saw to get back into an operational condition. I didn't pay enough attention while working on a project and nicked the attached power cord. Needless to say, it never quite functioned the same after that- plus, the wiring would get super hot and occasionally arc! So it needed to be cut and re-spliced.
This repair procedure is meant to be used for devices that encounter residential or light-duty use. Do not follow this procedure if you are repairing a device used in an industrial or heavy-duty setting.
Keep in mind that this repair is working not only with a power tool, but also with a power cord that plugs into the wall. Be slow and careful with this repair to minimize the dangers involved.
필요한 것
There are three parts to the power cord on this circular saw.
There is the outer casing, that protects the wires from the normal wear and tear of the workshop.
There are the wires that carry the electricity.
There is some string. The string is there for added strength in the cord.
In the close up view you can see that the black wire is cut completely through.
Get your soldering tools ready. You need a soldering iron and solder.
You also need some insulation. You can use either heat shrink tubing or electrical tape.
In this guide we used heat shrink for one wire and electrical tape for the other, to show how you would use each one.
Splice the wires together by wrapping them around each other.
Solder the wires together.
Put a little bit of solder on the tip of the iron.
Hold the iron to the wire, and add the solder to the joint. When the wire gets hot enough, the solder will melt and suck itself into the wire.
Add enough solder and move the iron around enough to make the entire joint silver colored.
Once the wire is cool to the touch slide the heat shrink so it covers the joint.
Use a heat gun to shrink the heat shrink over the joint.
If you are using electrical tape, start a small loop around the joint.
It's hard to fit the entire roll of tape through the space between the wires, so pull off some tape then tear it off the roll.
Wrap the entire joint in electrical tape. I always use a double layer, going up the joint one way, then back down to where I started.
Wrap up the entire thing in electrical tape.
If you have a really big section of heat shrink tubing that will fit over the entire joint you can use that as well.
The string got cut at this point because there wasn't room to put it all back inside
Again, wrap the wire with at least two layers.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 7개
Hi Eric
If i see a broken vacuum cleaner near the trash cans, i stop and cut the power cord of.In 95% the on/off switch ist broken, because the most people kick them like a foot ball.These power cords are mostly up to 7-8 meters long. Open the black handle on your saw and connect the longer cord to the saw. This gives you more room to secure handle the power cord and you'll never have to stop right in the middle of the cut...
Achim Krah - 답글
Never, EVER repair a cord like this! ALWAYS replace the cord with a new one!
1. The splice on this cord is not waterproof because there is no actual jacket there. Water + Electricity = DEATH!
2. The joint is weaker than the rest of the cable...if the cable gets snagged while in use, it would probably short cicuit.
3. Electrician's tape is notorious for coming unravelled over time, and thus will expose the wires underneath.
The absolute best thing to do is take the saw apart, buy a piece of cable the desired length with a grounded plug, and replace all. If this repaired saw were being used on a work site, OSHA would impose a rather hefty fine.
When going thru the required items listed, when you select the heatshrink list, the repair will abort and shutdown.
I would have used heat shrink insulation tubing on each wire and not soldered them then finally slid a length of heat shrink insulation tubing that has an adhesive layer that melts over both wires. It's quick, strong, easy, cheap, and safe (waterproof and all Charles) LOL.
The biggest reason for NOT repairing a cord this way is because any splice or connection in a wire causes a higher resistance in the wire, thus raising the amperage. If you are using the power saw with a 50’, or 100’ power cord you increase the amperage pull even greater. Amperage causes heat, and heat causes decay. The splice is already weaker than the rest of the cord, and over a surprisingly short period of time the splice will become unreliable at best, extremely unsafe at worst. I also would strongly disagree with using a vac cord as replacement as vacuums are not rated for as high an amperage draw as a power saw. Vacuums use a 16 or even 18 gauge wire i the power cord. A power saw will use 14 gauge at the least.
Being an electrician i need to stress that the comment made by Dave back in 2012 is the only true answer here: not only do you risk a fine and the life of the operator, any electrician could easily lose their job by fixing the power cord this way.
1st: The String inside the cord is there to make shure the cord withstands drag forces. Obviously the 2 wires won’t be able to, after being soldered together.
2nd: never ever use a soldering iron to fix some wiring like this. This is bowling, there are rules!
3rd: open the saw and REPLACE the power cord as a whole! Any power cord should be repaired at its end, not somewhere else.
So I thought I would be smart and replace the entire cord assembly. It was a simple fix. Unfortunately, simple and easy are not always the same. I opened the handle and saw where the two (in this case) wires went into the switch. The wires are secured by pressure, so I wiggled the white wire out, with no problem. The black wire was a different story. It broke off inside the port. Okay, so I try every possible way to bypass the remnant of the old wire and insert the new wire. This did not work. As a last resort, I contacted Craftsman to order a replacement switch. They don't make the part anymore and don't have the part in stock. I hate throwing a good saw away. I've looked online for an aftermarket part or an identical model that is being sold for parts...no luck. The switch mechanism seems to be sealed. Is there a way to open it up so I can clear the old remnant and install the new wire? I guess I should have stuck with my original fix, which is much like the one you outlined above. Any suggestions?
