주요 콘텐츠로 건너뛰기
Craftsman Model 315.10721 Blade Replacement
필요한 것
  1. Craftsman Model 315.10721 Blade Replacement, Blade: 1 단계, 이미지 1개 중 1개
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
결승점
작성자
5다른 기여자 명과 함께
Riley Hilliker
회원 가입일: 10/14/14
557 평판
안내서 5개를 작성함
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G47
4 회원들
안내서 5개를 작성함
2가이드 댓글
Where can I get replacement blades for this saw.
Edward - 답글
Where can I get replacement blades for this saw?
Edward - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 54
전체 시간: 4,354
