주요 콘텐츠로 건너뛰기
Craftsman Model 315.10721 Brush Replacement
필요한 것
  1. Craftsman Model 315.10721 Brush Replacement, Brush: 1 단계, 이미지 1/2 Craftsman Model 315.10721 Brush Replacement, Brush: 1 단계, 이미지 2/2
    • Using a flathead screwdriver, remove the brush caps on the outer casing of the saw near the motor.
  2. Craftsman Model 315.10721 Brush Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver or a small diameter nail, carefully pull out the washer.
    • The washer is seurely held in place and may require force to remove
  3. Craftsman Model 315.10721 Brush Replacement: 3 단계, 이미지 1/1
    • After the washers are removed, gently grab the old brushes and remove them from the motor.
    • When reassembling make sure the curvature of the brushes match curvature of the motor.
결론
Riley Hilliker
회원 가입일: 10/14/14
557 평판
안내서 5개 작성하였습니다
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G47
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 1,405
