주요 콘텐츠로 건너뛰기
Craftsman Model 315.10721 Switch Replacement
필요한 것
  1. Craftsman Model 315.10721 Switch Replacement, Switch: 1 단계, 이미지 1개 중 1개
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
  2. Craftsman Model 315.10721 Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #1 screwdriver, remove the 1/2" silver screw that is securing the switch.
  3. Craftsman Model 315.10721 Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the switch are plugged in.
    • Release both sets of the black and white wires and gently pull them from the leads.
    • To install the new switch, insert the wires of the new cord in the same way that they were removed.
결론
작성자
3다른 기여자 명과 함께
Riley Hilliker
회원 가입일: 10/14/14
557 평판
안내서 5개를 작성함
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G47
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 1,601
