주요 콘텐츠로 건너뛰기
Craig CMP801 Battery Replacement
필요한 것
  1. Craig CMP801 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Craig CMP801 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: 2 단계, 이미지 1/2 Craig CMP801 Battery Replacement: 2 단계, 이미지 2/2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: 3 단계, 이미지 1/2 Craig CMP801 Battery Replacement: 3 단계, 이미지 2/2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: 4 단계, 이미지 1/3 Craig CMP801 Battery Replacement, Battery: 4 단계, 이미지 2/3 Craig CMP801 Battery Replacement, Battery: 4 단계, 이미지 3/3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: 5 단계, 이미지 1/3 Craig CMP801 Battery Replacement: 5 단계, 이미지 2/3 Craig CMP801 Battery Replacement: 5 단계, 이미지 3/3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Duyen
회원 가입일: 09/25/17
281 평판
안내서 2개 작성하였습니다
댓글 한 개
Where do I find a battery cmp749 ???
kourriclay929 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 26
전체 시간: 1,003
